Description
It is the smallest model of the series Mommotti and its sinuous swimming, which distinguishes the models of superior size, seems to find a perfect realization with its small size. Mommotti 115 SF, however, has “an edge over” the other models of the family, thanks to a particular internal construction called DCG: Dynamic Center of Gravity.
With its 115 mm and a weight of 12 g is the lightest model in the series and is a very valid lure for all sea and fresh water predators of small and medium-sized, but it is definitely perfect for seabass.
What is the D.C.G.?
The DCG is an internal system, which basically allows the Mommotti 115 SF to jerk more marked than usual. In practice with the DCG the internal mobile spheres, which are normally blocked in a very narrow space when the lure is swimming, are free to move in a larger space and their backward movement during the jerks creates a greater instability of the lure balance which makes wider skids.
