Coixedda 130
Against all odds
  • Darter minnow, sinking. Designed especially for shallow water
  • ABS Body – Length: 5.0” – Weight: 9/10 oz. Depth range: 0.3’-1.3’
  • Moving inner weights for long casting.
  • Inner armor and SW round hooks, super sharp saltwater resistant, n°2 #2/0 or you can use 2x, #2 size
  • Searching bait to explore an extensive area
20,50
Share This:
Description
Coixedda 130, the big brother of the Coixedda 100, is a compact shallow minnows, sinking, characterized by an irresistible swimming with a sinuous wag even at low speeds and the ability to withstand the current and waves despite the very little sinking. These features, combined with a long cast in often prohibitive conditions, makes it perfect to fish in shallow waters searching seabass, or for all situations where a realistic minnow that swims just below the surface is needed. It is the typical searching bait to explore extensive areas. In order to support its swim in shallow waters without risking to run aground on the rocks, Coixedda is commercialized with n°2 saltwater round single hooks with the eyelet aligned with the point, especially design for hard bait, but it can be also safely used with 2x treble hooks, # 2.
Additional information
Available Colors
ACC, AGU, AGUP, ALR, BAR, BLUE-AYU, BRZ, CEF, GBA, GLWG, MUL, SAR, SARR, BCR
In Action
Availability
Scroll to top
